two body separate in ax 2009
I have used two body’s.(AX 2009)
e.g.i have attached screenshot,i want to red or blue body are separate,but problem is that two body are mix up.i want to display separate red body or Blue…
please help me…
Sangram.
What body are you’re talking about?
Also, there is no screenshot. Please try to be specific on Body and how they are mixing? Not sure if it form or report.
Pranav…
Hi Pranav,
I have attached Screenshot,please check and let me know.
Thanks Sangram.
Hi Martin,
i have used two body.
e.g. A and B, but problem is that A body overlap in Body B,I want separate two Body using fetch method.Please help me.
Fetch method… Ah, it seems that your question is related to MorphX reports. Nevertheless fetch() method is used to obtain data, it doesn’t define formatting.
Could you explain what you’re doing, what’s the problem (I still don’t see any screenshot) and show us your implementation of the bodies in question?
