I have a requirement to filter the records in a listpage depending on a Combobox filter. The combobox changes the datasource query with a complex statement, which is the reason I can’t use the properties on the Control itself. My solution now would only need the interaction class to trigger when my selection on the Combobox changes. I know that the method selectionChanged() on the interaction class gets called each time my selection on the record changes, but that’s not exactly what I’m looking for and I really don’t want to use that, since the user would always have to click on another record before the query changes…
So, is there any way I could trigger the interaction class through my form control?
I never found a solution for this, but we came to the conclusion that it’s not optimal to filter on a listpage since it’s suppose to only display information. Rather than filter on the listpage, you can implement the filter on the Details form. Another option would be to create new queries with the filtered data for each option you need and use them in a new listpage (this is how Microsoft does it).
Hi, I’m having exactly the same problem as the OP (except we don’t use the EP in AX 2012 R3). Now with planned demise of EP in AX 7, just how relevant is the DisplayTarget property going to be in the future?
