Trial Balance issue
Good day all.
We are using D365 F&O and have just completed a data migration exercise migrating from Nav to F&O. Our first attempt to run a TB has not worked it brings back no data. We have also attempted a snapshot which also doesn’t work. not too sure if there are batch job errors stopping the TB’s running etc (process automation doesnt appear to work) or something else. any advice where to start looking would be great
Thanks as always
This typically occurs when something is incorrect with the way the data migration was finalized or if the posting/ledger setup isn’t fully aligned. A couple of things you could check:
  • Make sure the opening balances or journals were actually posted into F&O after migration (sometimes they get stuck in staging).
  • Verify that the process automation/batch jobs related to financial reporting (like Ledger balance dimension updates) are running as expected.
  • It’s also worth checking if the Financial Reporting database sync has completed, if that hasn’t run, the TB won’t show anything.
I’d start with batch jobs and the posting history first, then move to Financial Reporting setup. That usually narrows it down.
Hope this helps point you in the right direction.
On Financial Dimension Sets, run the Calculate balances function. That should fix this.
Hi @MDC
Is the issue resolved. Or is something you still feel might need a helping hand
