Hi All
I have created a expense report and submitted, But i am unable to approve from EP or Rich Client
Do i need to set any user permissions or workflow error , i am unable enable post option
Please suggest
TX
Varma
Hi All
Please suggest
TX
Varma
What is the problem you are facing here? Are you not getting the Approve action item? If Yes, view the error log description in the Actions=> View history and specify here.
Yes, you need to setup the expense report workflow configuration template accordingly and login with specific user/role etc to get the options enabled for you. The post option will be available through AX rich client only, once you approve the expense report.
Thanks Kiran
May i know which user role to be asigned
Varma
“Employee Role” would do that!
Assigned Employee Role still unable to enable post option
Have you defined the workflow template? You can select any of the assignment type, for example say User: select any specific user and login with this user to get the approval action item in the expense report.
hi Kiran
I have even created expense approval workflow
but still i am unable to approve
assigned roles appropriately
can u suggest me workflow components like work item ,Instructions ,assignments
Appreciate your help
Varma
