would like to ask for a link where I can find the Transformation Input File Editor installer., where I can do this:
You can Find Transformation Tool folder in your DVD.
Which DVD? The Microsoft Dynamics NAV? What if the DVD is missing? is there other way?
You can download NAV2009SP1 Transformation tool from this link
Hi Mohana,
I followed these steps, http://blogs.msdn.com/b/nav_developer/archive/2008/06/13/nav-2009-how-to-simple-form-transformation.aspx
but I can’t proceed to number 4) Click Import → “Import PageType - FormType mapping”, and select the file TransformationTool\TIF Editor\FormToPagetypeMapping.txt.
after I run the Transformation Forms, there is only Setup,Functions & Input button. Where can I find the Import button since there is no import button under file as I already run the Transformation Form?
It should be under Setup -->PageType - FormType mapping
Dear Mohana
Really really thanks for share that link for downloading a transformation tool, i struggled a lot with microsoft downloaded tranformation tool it hasn’t give the full information in that once again really thanks.
Rishi Chourey
Welcome Rishi…
Evening
You should always search for the newest version of the TIF-tool. Definately NOT the one found on the DVD - it is YEARS old.
Latest version can be found at: http://www.microsoft.com/en-nz/download/details.aspx?id=26681
