Transferring assets between business central
Is it possible to transfer assets between entities in Business Central or there is no native functionality?
You can merge assets for the same entities, you can make sub-assets but I guess migrating the one from one entity to another altogether isn’t available in the out of box functionality.
Thanks. Not looking to merge to the same entity but knowing its not possible to transfer between them helps. Appreciate the answer!
Hi RockWith,
Another topic but tying to the multiple entities, Is consolidation native in Business Central?
You mean, Consolidation of Companies?
Yes it is.
  • No, It’s not possible Straight away
  • The Workaround solution Here is to
    • Pass General Ledger Entry using Inter Company Module B/w Entities
      • For Acquisition as well as Depreciation
      • Use Fixed Asset ID as Dimension
After Posting the Transaction in receiving entity, Setup Fixed Asset and Transfer the General Ledger Balance to Fixed Asset Using Fixed Asset G/L journals.
