Does anyone has found any use for the following data types : - TransactionType - DateFormula tarek_demiati@ureach.com
Tarek DateFomula type will check the input for a date formula is valid! like if you wanted to set a reminder for a yearly Subscription say you input “-30D” the DateFormula data type would validate the Input. If you typed in “-30Days” you would get an Error so it does have a use! It’s Strange that Navision Don’t use them in the Payment Terms Fields, Lead by example, It seems to Save setting the Field property to Date Formula. TransactionType looks like a SQL DataSet Type SnapShot? Mr David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk Edited by - David Cox on 7/9/00 10:55:56 PM Edited by - David Cox on 7/9/00 11:02:24 PM
