I a trying to Create a Functionality to track all the Ites with Same Shipment Date, Item and Location Code. Is there anything somebody can add on few comments on this or any thing existing which I can refer to…
Hi, You can create a report using “Sales Shipment Line” and “Sales Shipment Header” tables.
Thanks Rajesh… I have created a form where all the sales Line can be seen with the filters Shipment Date, Location and Item. Then I created a batch window (same as that of the normal tracking in the base), where I add up all the quantities with the filters mentioned above, once the different lots have been assigned it sorts the existing sales lines and assigns the lots and then creates the Tracking entries… with this I have a problem at times… but not always… so… ur idea of Reports… I am not so clear… can u please describe more… becasuse the user needs to see the sales Lines and then Invoice after Tracking and shipment on the same screen…
