Hi pioneers,
While registering the items in purchase orders, came to know that only some of the serial numbers recorded
in the from Serial numbers . (Path: InventoryAndWarehouseManagement\Inquiries\Dimensions\Serial numbers)
I found the reason behind by debugging, When certain conditions are met then a record is
created in InventSeriaTable.
\Classes\InventMovement\updateSerialNumReceipt
inventDimGroupFieldSetup = this.inventDimGroupSetup().getFieldSetup(fieldNum(InventDim,InventSerialId));
if (!inventDimGroupFieldSetup.isActive() || !inventDimGroupFieldSetup.isSerialNumberControlEnabled())
doUpdate = false;
if (doUpdate)
inventSerial.insert();
From above script came to know that Insertion of InventSerialTable is not triggering in the Items which holding Tracking dimension group with the setup
Serial number control - not enabled,
serial number active - not enabled.
I would like to know what is the reason behind linking of recording serial number in InventSerialTable
(creating record in InventSerialTable) only when the above conditions has met.
