I have to create a report that lists the top 10 customers based on their orders…So if we have 130 customers i need to display the top 10 customers that have the most amount of orders. I need to display the customer along with the total amount for that customer orders. i tried using report 111 (Customer - Top 10 List) as a starting point but this report doesnt help me much as it is based on the customer table and not on the sales of the customer.
Although report 111 builds the information from the customer dataitem, it is using the “customer amount” table as a temporary table and then uses the integer dataitem to print this. The same design should work for you.
I cant use the Amount field in the customer table…i have to use the Amout field in the Sales Header table because i have to filter on the field “Document type” = order.
I dont want to see the customer’s total amount i want to see the customers total amount based on their orders. Thats why this report seems so difficult for me. but yes the output should be the top 10 customers
I dont want to see the customer’s total amount. i want to see the customers total amount based on their orders. Thats why this report seems so difficult for me. but yes the output should be the top 10 customers
Never use Document tables for reporting! It can be used to print out documents later. but REPORTING --analytical, summarizing, etc, etc-- must be based on Ledger tables (+Detailed), as only there FULL pricing & costing information sits. Document tables are NOT updated with real COGS info, what was grabbed from ItemCard at the moment of creation, that sits there forever. Then Pmt.Discounts further change actual sales amounts, too.
So your approach using Doc table(s) is wrong from the very beginning.
added: Besides - Doc tables can be easily cleaned up from posted documents to eliminate DB size, in contrary to Ledger tables, which never loose data, even if “compressed” for closed periods. One more reason NOT to report from Doc tables.
No need to apologize, just clarifying that it wont work is great, because it doesn’t send the next member on a wild goose chase trying to make this work. I am glad you worked out yourself that it wont work.
