Hello, I work with the Toolkit 1.03.When I open it, I can only find in my “Toolkit” database the standard objects. What can I do to see the objects I created? I tried to import in txt but nothing has change. Do I have to make some manual modification in the objects imported with DevTool.fbk? Thank You
hi john, you need to first export your objects in text format and then in Toolkit, click File-Import and then press F3 and enter a new custom version name.In the import tab, select the text file u exported.Then click import. Toolkit will then create a new version with your objects. hope this will work
Ok I just find it Tks.
