tool comparer for 3 objects
hi all… i have a project which is using nav version 4 and nav version 3.7
these are separate 2 databases… and different objecs in it
some are the same…some are different
they want to merge it become new version (NAV 2009)
what i need now is …
is there any tool to compare 3 different objects?
so i can compare for example table 36 (sales header)
there are 3 objects side by side… table 36 (version 3.7)…table 36 (version 4…0)…table 36 (version 2009)…
if you have or know about tool like that. please do let me know
thanks
CompareIt, Beyond Compare and Araxis
right now i’m using beyond compare version 3
can it compare 3 different objects?how to do that?
as far as I know.,… it only compare between 2 objects
Like this
how to make it become 3 columns?
mine only 2 columns?
what version do you use?
3-way Merge
Introduced in version 3, Beyond Compare’s new merge view allows you to combine changes from two versions of a file into a single output.
can you see the last option below menu items..?
Check here
http://www.scootersoftware.com/index.php
ok. thanks a lot Mohana
Welcome…
Dev Tool Kit is also an option, what i think.
