Hello,
Is there a way to change how the query parameters are display on a RunBase/RunBaseBatch form? Apparently I have to many data sources so some data source paramters are being ‘cutoff’ from the group. I can still add range values in via the Select button interface but dialog form just doens’t look right. For example, in a standard form, I would set the value of the parameter group control columns = 2. However, since its generated, I cannot.
Any ideas?
Thanks!
