I need to get record from table but not with key that is first defined like a primary key, then with second one that is defined. (because I have the fields from second key)
In order do that ,I done this:
Record.SETCURRENTKEY(Record.Type,Record.“No.”)
IF Record.GET(Record.Type::Item,Item.“No.”) THEN BEGIN …
But when I am runing, this kind of msg appears:
Microsoft Dynamics NAV Classic
"Too many key fields were specified, so Record could not be retrieved. The number of fields in the primary key is 1."
If I delete second line (with Get) this error doesn’t occurs.
Would U tell me what is reason for this error and where I am doing mistake.
Thanks in advance
