I would like to know whether it is possible to add a new field at the Item Requirements Line level having a Display method to show the ‘RESERVED PHYSICAL’ quantity for each item.
If yes, then is it possible that I can use any of the existing method?
or
Do I need to write a new method.I am new to AX coding, so in case I need to write a new method, can you please give a few tips to get started.
Regards
Thomas Philipose
You can make use of \Classes\InventOnHandQty\reservPhysical
create an instance of the \Classes\InventOnHandQty by using the new* methods available in that class
Dear Kranthi,
Thanks for the message
I had done the following:
- On the form ProjSalesItemReq - Methods - Class declaration added the following line
InventOnHandQty onHandQty;
Datasource- SalesLine - Method
Created a new method as follows
private InventQty getPhysicalResvQty()
OnHandQty = new InventOnHandQty(); // To initialise the Class
But i am getting an error as follows:
The method is declared protected and may only be called from methods in classes derived from InventOnHandQty.
When I checked in the Class, I found that the new method is a protected one.
How can I overcome this? Please tell me whether my approach is correct from a Theoretical point?
Since I am beginner, I would like to follow best practices, rather than some how getting the work done.
Regards
Thomas Philipose
Use the available constructors to create the instance of the class
Example: \Classes\InventOnHandQty\newItemId
