I’ve tried to clear record fields when i opened the form. How can i accomplish this? I know that it’s not difficult to make this.If I use CLEAR function to do this? But i don’t want to clear table records. I only want to clear form when the user open it.
I mean that when i select Item No. on the existing form. All the controls (text boxes, check boxes etc.) must be empty. But i’ve selected (changed) Item No on the lookup. Controls are not changed. Yes i am trying to insert a new record. If I use F3 to insert a new record it works. But I don’t want to insert a new record that way.
Please don’t do this. If you are a partner, then you need to explain to your customer how NAV works, and have them use the systme properly. If you are a customer, contact your partner, and have them teach you the proper way to use Navision.
