Hi Team,
In the Header table, my fields are No. (code=10), PV Type (Option=Purchase of Tbills,Short Term,Staff Advance) Global Dimension 1 Code/Dept.
In the Lines table, my fields are No (code=10), Account Type (Option=G/L Account.Bank Account,Vendor,Customer), Account No.,Global Dimension 1 Code/Dept.
In the Header table under Global Dimension 1 Code Validate() I wrote this below
IF Lines.GET("No.") THEN BEGIN
IF Lines."Global Dimension 3 Code" = '' THEN
Lines."Global Dimension 3 Code" := PV."Global Dimension 3 Code";
Lines.MODIFY;
END;
After run the Page, once I chose Global Dimension 1 Code/Dept in the Header of the page is not reflecting on the Lines
Thanks.
Sorry, but I’m not clear understand your start description. Could you clarify description?
- I can’t see where you “receive” (find) data for variable PV (it is for PV.“Global Dimension 3 Code”).
Could you set Breakpoint on the line with PV.“Global Dimension 3 Code” and check what data do you have here?
The PV is a variable in the Global Variable and its representing table Header.
Lines.RESET;
Lines.SETRANGE(No,"No.");
IF Lines.FINDFIRST THEN BEGIN
Lines."Global Dimension 3 Code" := "Global Dimension 3 Code";
END;
That is the new code I wrote above and after debugging I discovered the Lines.No = ‘’ and there is a relationship between the Header and Lines
which is No=FIELD(No.) under the Lines in the Card
and I can see lineS.
if you need to update all lines you need to write loop - something like Repeat…until Lines.Next = 0;
Only want to update Lines.Global Dimension 3 Code once I choose Header.Global Dimension 3 Code in the Page.
I think you need to have something like:
Lines.RESET;
Lines.SETRANGE(No,“No.”);
//if you need to update Empty values only you need to write: Lines.SETFILTER(“Global Dimension 3 Code”,’%1’, ‘’)
Lines.MODIFYALL(“Global Dimension 3 Code”, “Global Dimension 3 Code”, TRUE|FALSE);
P.S. we can “speak about” - esage of the “Lines.SETRANGE(“Global Dimension 3 Code”,’’)” instead of “Lines.SETFILTER(“Global Dimension 3 Code”,’%1’, ‘’)” or absence|presence of the line “IF Lines.FINDFIRST THEN…” but it is linked with version of NAV and quantity of records in the table…
Lines.RESET;
Lines.MODIFYALL("Global Dimension 3 Code","Global Dimension 3 Code",TRUE);
Its not seeing the Lines.No = ‘’ and its not passing the “Global Dimension 3 Code” of the Header to the Lines
I added this below code to OnInsert () of Lines(Table)
IF PVHeader.GET(No) THEN BEGIN
VALIDATE("Global Dimension 3 Code",PVHeader."Global Dimension 3 Code");
END;
Thank you, RedFoxUA
