As per our understanding, Entry No in GL Entry table is sequentially increasing and there will be no update on records after posted. It means timestamp and EntryNo fields should be incremented in ascending order but we have many records which are out of sync between timestamp and Entry No fields.
SELECT
CONVERT(bigint,timestamp) as RecID,* FROM dbo."*******$G_L Entry" WHERE “Entry No_” IN (202,203,204,205)
RecID | timestamp | Entry No_ |
2056433 | 0x00000000001F60F1 | 202 |
2056434 | 0x00000000001F60F2 | 203 |
2116148 | 0x0000000000204A34 | 204 |
2056436 | 0x00000000001F60F4 | 205 |
Check above Entry No ‘204’ the RecID(Timestamp) is 2116148 which is greater than 205 ( RecID is 2056436), in this case, we consider this as Delta record which is wrong by entry no. Please guide me on this scenario.
