Hi Is there any timer function in Navision ? What I required is to read a particular table in an interval of 5 minutes continusly in backgroud. Any Idea ?
Yes, in the UK (I assume it is the same elsewhere) there are timer triggers for each object from version 2.01 onwards. I do not know whether these work on the basis on actual time in HH:MM:SS or they trigger when that particular object is run. Can anyone tell me in which way these work ?
Joseph, see the “On Time Trigger” in this forum beginning of March! Or search om timer. Pelle
Ya its described on another topic here. I found it and its useful. Thanks
Just in case someone does not want to search, the timer function is in milliseconds. It will support from 1 to the maximum value of an integer (2 billion+). The timer property can be dynamically changed at runtime. Bill Benefiel Manager of Information Systems Overhead Door Company billb@ohdindy.com (317) 842-7444 ext 117
