After starting the firewall in Windows 2003 server, the user encounter timeout problem once they have enter the login password. Without firewall, everything is working perfectly.
If you are using the Navision database server then make sure that TCP/IP port 2407 is open. I don’t know if the same port is used when the database server is SQL server. Also make sure that the server.exe program isn’t being blocked by the firewall.
