This report can't be run for a time period of more than 31 days
Hi There
Am unable to run the dimension statement as below error keeps showing
  1. This report can’t be run for a time period of more than 31 days.
could you help me please ,
The message tells you that this report doesn’t allow a longer period than 31 days. The amount of data for a whole year would be huge and running the report would have impact on performance of the system. But if you insist, you (your development team) could modify the logic.
Thank you martin ,
The report used to be ok 3 days ago the after the below update 10.0.29 do you think it will impact …
According to code in 10.0.29 (in LedgerTransStatementContract.validate()), this check is used when LedgerDimensionStatementReportPeriodLimitFlight is enabled.
Hello Abed_Nasser,
Did you solve this issue?
Hello, I am having this same issue too, Please anybody with a resolution? Users can’t run Statement report past 31 days
Report it to Microsoft, as of 10.0.29 they have posted a flight to limit that report for performance reasons if I read what Martin is saying correctly. In summary that means the author of the software has chosen by design to limit the range.
Hi Adam, what is the standard report that can generate the same data do u suggest ??
The standard report is the report they have now limited as per the release, which means if you want a report to run over the limitation you need to design it yourself or log a call to Microsoft to explain why the flight has been introduced and what options exist with the flight in place. If it is performance related as a limitation there will be little.
The report works fine now
Hello, can you share the solution?
I have recently upgraded, I am facing the same problem.
