Sorry, I am opening a new post to handle this issue separetely from my last post. I am in a data migration process using Administration>Company Setup>Data Migration menu to load data into Table 81. I am getting back the following error message:
There is no Currency Exchange Rate within the filter. Filters: Currency Code: USD, Starting Date:”…”
Filter Caption: Amount
I am using USD reporting currency. Did anyone encounter this problem in the past ?
I have populated both FCY and LCY amount fields of General Journal line so that the system can generate the Currency Factor itself. USD is my foreign currency.
I had done that. currency exchange rates have been set up with a valid starting date. It looks like the system is not taking into account the posting dates in the General Journal lines.
Dave is absolutely correct.
You have to create an exchange rate for USD, but leave the starting date blank.
This will NOT be used by the system so there’s no risk in doing that.
My best guess is (i’ve never actually looked at this import-routine) that the import validates whether or not an exchange rate exists, BEFORE it enters the posting date.
Since you run into this rather basic issue at this point, i’m sure that you encounter this problem in a test-environment, not in live database/company.
So what is the risk to just try to create an exchange rate, and define some totally ridiculous rate, then you can for sure see that it is the correct rate that is used in the end.
I do have currency exchange rates set up for USD with a valid starting date. (NAV does not accept to leave the starting date field Blank!). This is the first thing I checked when I encountered this problem. I think the problem is somewhere else.
And yes, you are right: I am using a test environnement. Thanks for your support.
Using the debugger, I can see that the Date value is blank. NAV is trying to find a currency with a blank date. Amount and Currency values are well transfered but surprisingly not the Date. The import in NAV from Excel file is working well. But it seems that the Date information is lost when trying to validate the line.
The data migration tool validate each field and when validating the amount field it check for the currency factor at the posting date hence the error. Are you sure you mapping “Posting Date” and not “Document Date”?
I have tried what you suggested with no better chances. I have changed my database to the Cronus database and the result is the same. Apparently, for some reasons, the “Posting Date” is lost during the validation process when using the Excel mapping tool to populate general journal line (table 81). May be this is a bug !!! What do you think ?
For those who would like to try to reproduce the case, here are the steps:
Export Posting Date, Amount, Amount LCY, Currency fields from Table 81 to Excel file using Administration>Company Setup>Data Migration
Populate the excel file with one line. Make sur you have a foreign currency entered in the Currency field. Do not leave blank. Add also an Amount, an Amount LCY and a Posting Date
Import the file back to NAV.
Validate the entries with “Apply Migration Data” on the “Migration” button
The following errors should appear in the Migration Errors column: "There is no Currency Exchange Rate within the filter. Filters: Currency Code: USD, Starting Date:”…”.
Please let us know if you have a chance to try these steps.
Which version are you on?
I just tried to reproduce the error, according to your instructions above, but didn’t get any error.
I even tried to delete the value of the posting date in the excel-sheet, so there’s no way any date could come from there, and still no error message.
I tested in a 5.0 SP1, CRONUS Denmark (danish version)
I am using Dynamics NAV 6.0 French version. Are you using a multiple currency as suggested ? Have you entered a foreign currency code in th Currency field ? This important as I get no error as well with Currency set to Blank. Please confirm.
I will try same on my side with 5.0 SP1 and let you know.
If you in a data migration process using Administration>Company Setup>Data Migration menu to load data into Table 81. and getting back the following error message:
If you have set the Exchange Rates Correctly then:
I have tried this and it works, If its Opening Balances, then on the Bank Accounts Card, Remove the Currency Code for all Bank Account s Involved, then Upload the Data. BEFORE Posting, SET again the Currency Code.
