The XML Parser return the following fatal error: Unable to switch the encoding
While opening the Navision, it shows below message:
Microsoft Business Solutions-Navision
The XML Parser return the following fatal error: Unable to switch the encoding.
Line Number = 1 Column Number = 55
Web service transaction gives error message as:
This message is for C/AL programmers:
The call to member send failed. MSXML3.DLL returned the following message:
The operation timed out
I have installed MSXML6, it was working before, now for the last 2 weeks it;s not.
Please help
no body know this ? [:S]
Hi, which NAV version are you using?
Can you check if MSXML parser library is corrupted? You need to run the command prompt (cmd.exe) with adminastrive rights and run this command:
sfc.exe /scannow
sfc.exe /scannow shows error message "You must be administrator running the console… "
But, I logged in as administrator, and I even ran the cmd by right click >> ran as administrator >> put the admin password and opened the cmd.
Still it is showing same error.
[:O]
And I am using nav 4.0 SP3. I think no issue with this version, because it works in another PC.
The issue seems to be with the system MSXML, but, it still occurs even after re-installing it.
