I am using nav 2009sp1 classic
I created new Database for Test.
And i restored the Live Db Backup.
While doing that i m getting the following error.
The following SQL Server error or errors occurred when accessing the Change Log Entry table:
[b][b]9002,“42000”,[Microsoft][ODBC SQL Server Driver][SQL Server]The transaction log for database ‘DB’ is full. To find out why space in the log cannot be reused, see the log_reuse_wait_desc column in sys.databases
SQL:
INSERT INTO “TEST_DB_210513”.“dbo”.“NAV 9 16-12-10$Change Log Entry” WITH (REPEATABLEREAD) (“Entry No_”,“Date and Time”,“Time”,“User ID”,“Table No_”,“Field No_”,“Type of Change”,“Old Value”,“New Value”,“Primary Key”,“Primary Key Field 1 No_”,“Primary Key Field 1 Value”,“Primary Key Field 2 No_”,“Primary Key Field 2 Value”,“Primary Key Field 3 No_”,“Primary Key Field 3 Value”) VALUES (6966575,{ts ‘2012-04-05 07:40:53.907’},{ts ‘1754-01-01 13:10:53.907’},‘MURTHY’,27,7384,0,’’,‘Yes’,‘No.=92016-27-04/13-05’,1,‘92016-27-04/13-05’,0,’’,0,’’)
[/b][/b]
