Upgrading from NAV 2009 R2 to NAV 2013 R2.
- Done object migration from 2009 R2 to 2013 R2
*Import Upgrade601701.1 in 2009 R2 and Transfer Old data process
*Delete Objects
*Open 2009 R2 in 2013
*Open 2013 in 2013 R2
*While importing Migrated objects in 2013 R2 i am getting below error.
Microsoft Dynamics NAV
The server “Server Name” was unable to process the request. The application will close.
OK
What object types are existing in Importing file?
any forms/dataports?
Hi mohana,
Table, Page, Report, codeunit
Asharaf P
Is there any service running for NAV2013R2 database?
Hi mohana,
Yes.
When i tried without service it throw 1 error to start service.
Asharaf P
It might be some issue in the file.
Did you check eventviewer whether there is any info?
Yes i have checked the EV.
There is no much info
it shows ‘#’ hexadecimal value 0*0f, is an invalid character, Line 12, Position 142.
Asharaf P
Did you check txt file whether it has any hexadecimal character as specified at line?
I have checked it. But NO.
i have noticed that in Caption Turkish characters are there. Is that a problem?
I am not using any Turkish.
Asharaf P
Not sure but can you delete Turkish Caption if existing in that line and try?
Is it possible the server you are working on has different languages installed but not Turkish so specific alphabet letters of the capionML are not properly identified?
Seems to be fixed with this KB, included in Cumulative Update 6.
