The problem I'm experiencing in operation-based production
Hello,
We are defining a leveled bill of materials on the material cards.
At the highest level, we have our product code.
Below that, in the semi-finished product definitions, we select “Pegged supply” as the “Line type”. This creates a 6-level bill of materials.
At each level, we define operations that are interconnected. The lowest level is 10, the next level up is 20, and so on.
We are experiencing a problem here. For example, I opened 5 production orders for the main product code and started production.
After completing 1 unit of production belonging to operation number 10 at the lowest level, it should move to production belonging to operation number 20.
Because that’s how we proceed in production. However, the system doesn’t do this.
I can’t move to production belonging to operation number 20 until all production belonging to operation number 10 is completed. Is there a solution to this?
If anyone has a solution, could they contact me to discuss the details?
Hi @Volkan_Gultekin
This is a classic manufacturing challenge in F&O, sequential operation blocking preventing parallel batch flow.
The issue is standard F&O behavior, but it’s definitely solvable with the right routing and scheduling configuration.
We actually worked through a similar scenario with one of our customers back in 2025 and got it sorted. If you’d like help exploring this, we’re happy to jump on a call and discuss your specific routing setup.
E: Hardik.gupta@allgrowtech.com
are you making discrete goods or something more process/batch oriented?
i think the process manufacturing system allows for “batch overlap”; not sure if that’s something that can be done in a discrete manufacturing paradigm.
Please check the Bill of Materials level sequence
