The item are purchased received or registered
Batch order quantity 200,000 total inventory transaction in the batch order is 142,800.
now we want to end this batch order by 142,800 but system gives error that.
Quantity ordered cannot be reduced because there are not enough open inventory transactions with the Ordered status.
The items are purchased,received or registered.
How about the remaining qty? What is the inventory status?
remaining quantity is not the production.earlier it was decided 200,00 but later only produced 142,800.Inventory status is started.
So the batch order is started with 20000 and you want to end it with 142800. How much qty has been posted in RAF?
Look at the inventory transactions related to batch order to know the inventory status.
batch started with 200,000 and we want to end with 142,800.in RAF 142,800 posted.
in inventory status also 142,800 available.
What is the receipt status for the remaining qty in inventory transactions?
there is no transactions of the remaining quantity.as far as I understand system should show it as ordered but no such status transaction available for the remaining quantity
What value does the Report reminder as finished shows?
report reminder as finished shows value 57,800 which is correct
Then there should be an inventory transaction for that.
RAF journal for zero with end job ticked. Create no picking or routing journals.
No Mr.kranthi no inventory transaction for the remaining quantity
