I have converted a Page from Form by Transformation Tool.
I encountered the error 'The Input method is obsolete.'while opening page.
How to solve this error?
Can you be able to compile the page?
Hi Mohana,
Yes, Page is compiled & saved.
Check whether you have any boolean variables which are used for changing the field editable / visible properties has Includeindataset property yes.
or check whether you can upload your page here.
Dear Shruthi,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
