The Hunt for a Navision Specialist
It is a niche market, and you are considered as the ‘Masters’ of this environment. I have this opportunity, that may touch your curiosity level.
This individual will work in an office environment alongside another developer in a team of 5. You will be working between 1 - 4 projects a day, depending on how important the project is. It is your responsibility to prioritize your work accordingly, and complete these projects. Our client seeks a candidate who is a professional in this environment. 80% of your job is developing and 20 % includes testing and researching. You must be a strong candidate in coding, ‘obviously’ using a lot of logic in your planning and of course have a background in SQL and Navision.
If this sounds like you, and if you are up to the challenge, then this hunt will be over. The job is located in Toronto, Canada; and if you are within the vicinity, give me a call , name your rate, and lets make this happen.
Cheers
Geoffrey
416-927-7575 x 249
