The format cannot contain the specified interval.
I Just Try to create a NumberSequencefor the customer following error was throwing.
If anyone help me please???
Please give us details about what you did.
Make sure the smallest, largest and number sequence format are consistent. Atleast largest number and # in format should be same.
Pranav…
Thanks Pranav…
Let verify it
As per your guideline,i verified.
If we try to decrease the #,the error was throwing
Thanks Pranav.
Please don’t forget to mark the verified solution.
Sure.But have question,if we decrease the Hash(#) error was throwing.
Since why we can’t decrease the # ??
If any specific reason revert please
You can always decrease or increase the #. Just make sure that largest number field contains exactly same number of “9” as per the #. For e.g. If you set the number sequence to have 6 digits and thereby enter 6 # characters, make sure that the largest number has only six “9” in there.
The message which is popped up is a warning and you can safely say “OK”.
Subsequently update the largest number field and you will not receive any warnings / errors.
Hope that helps.
