I’m trying to test out the link to report feature that is mentioned on http://blogs.msdn.com/nav-reporting/ under the http://blogs.msdn.com/nav-reporting/archive/2009/07/07/what-is-new-in-dynamics-nav-2009-sp1-for-reporting.aspx posting.
I have the example code:
=“DynamicsNAV:////runreport?Report=104&Filter=Customer.%22No.%22:”+Fields!Customer__No__.Value
which I am trying to test in a browser using:
DynamicsNAV:////runreport?Report=104&Filter=Customer.%22No.%22:10000
as my URL. Just to check to see if it is all working correctly.
When I try this I get the error message “The filter string contains invalid parameters.”
I am trying this out on the NAV 2009 SP1 Virtual PC image that is available from PartnerSource.
If I use the URL:
DynamicsNAV:////runreport?Report=104&Filter=Customer.Name:The Cannon Group Ltd.
it works and shows the report for the correct customer.
Does anyone have any idea why this might be not working?
