Anyone looking to forward and or backward test applications may want to take a look at Time Machine. www.solution-soft.com
W/ virtualizaton being so popular this software uses simulated/virtualized time clocks rather than the sytem clock to assist in testing applications. As most of you know chnaging the system clock to test can be hazardous to the environment let alone quite time consuming. Time Machine makes it easy and eliminates the wasted time and resources.
SD
