Hi guys!
I have a requirement for preventing multiple sessions for a specific user.
Please help guys!
Thanks!
AML
Hi guys!
Please help guys!
Thanks!
AML
Find it here.
Hi Vishal Tiwari
How about terminating and shutting down the previous session?
Looking forward to hear from you very soon.
Thanks!
AML
Basically that depends on your requirement, if you want you can do that. Change the code as per your need.
Hi Vishal,
I can terminate the previous session but I don’t know how to shutdown it. The window of the previous session is still visible. I use the function “this.shutdown” but it will shutdown the newly opened session. do you have any suggestions?
Looking forward to hear from you.
Thanks!
AML
Find the session id of the previous opened AX using session.sessionId().
And use info.shutdown(true) where the session is of previous AX.
Hi Vishal,
Please check my code:
SELECT * FROM SysClientSessions
ORDER BY SysClientSessions.LoginDateTime ASC
WHERE SysClientSessions.userId == userId
&& SysClientSessions.Status == 1; //SELECT THE PREVIOUS ACTIVE SESSION
OrigSessionId = SysClientSessions.SessionId; //GET THE FIRST SESSION OF THE USER
session = new session(OrigSessionId); //SELECT WHAT SESSION TO TERMINATE
IF(session)
session.terminate(session.loginDate(), session.loginTime()); //TERMINATE SESSION
AML
HI AML,
Even i have the same requiorement are you able to complete the functionality. If means can you please send me the code to pavan1363@gmail.com
Regards
Pavan
