I’m about to do a technical upgrade from NAV4 SP3 to Classic NAV2009 R2. We will continue to use the NAV database server.
Others have said that the database size after the technical upgrade causes a shrink in database size with the SQL Server database if you restore from a backup file. Does this also happen with the native NAV server? I gather that it does not happen when opening and converting a v4 database.
No it does not. The reason why there is a difference on SQL Server is the way that SIFT is implemented on that platform. On native, SIFT has not changed, and should therefore not cause any significant file size reduction.
