Dear all,
I am facing a problem while running the vendor table. it takes really long time and the software crashes. how can i solve this problem?? By the way i have created a lot of flowfields in this table. is this the reason for this problem??
Thanks in advance
Yes. All those must be calculated on the fly to display values.
BTW - HOW much is a lot of?
Thanks for the reply. i have more than 50 fields as flowfields… is this the problem takes long time to open the table??
Yes, more no. of flow fields will reduce the performance…
Thanks for your help … i have solved the problem …
50 FlowFields ???
Why you need THAT much? If those all are made visible on the list, I wonder if it opens at all in reasonable time [:O]
