If any one know , which tables are affected in bank payment
Hi Shonali.
There is an option called " code coverage " is available in navision to findout what are the objects are getting affected in a particular transaction.
Tools->Debugger->Code Coverage. to use this code coverager do the below steps
1.creata a bank payment voucher
2.Go to Tools->Debugger->Code Coverage (a new screen will be open)
- Click the start button on that acreen
4.Press Esc key
5.now post the bank Payment Voucher
6.Now go to Tools->Debugger->Code Coverage (This will show you what are the objects are getting affected because of bank payment).
7.Do the same fo contra also
Jerome Marshal.J
Its Depends on what entry you are posting.
Hi Manish
the entries may different any way the code coverage will show you the what are the
objects has been affected because the particular transaction. so no need to worry abot the type of transaction
Jerome Marshal.J
Code Coverage will show all the objects where ever the code is being triggered after posting the entry.
Sonali required which tables are affected in bank payment.
Main Tables affected are GL Entry, Vendor Ledger, Detail Vendor Ledger, Customer Ledger, Detail Customer Ledger, Bank Ledger.
Then again it depends on what type of entry are you posting, entries which included TDS,Service Tax, Fixed Assets.
