Table Relation with multiple filters
I have the following table relation on my Table which allows the user to select and item # from the item table. The list of items that you can select from is filtered to only display items there the “Item Category Code” = ‘ROLL STOCK’
I would like to add an ‘OR’ clause to it so that I can add another Item Category Code = ‘Sheet Stock’
Yann
field(50084; "Paper Item No."; Code[20]) {
    TableRelation = Item."No." where ("Item Category Code" = filter ('ROLL STOCK'));
Just extend the filter:
where (“Item Category Code” = filter (‘ROLL STOCK|SHEET STOCK’))
Although, I would suggest to avoid hardcoding filter values in table relations - these values tend to change with time. Much better if the filtering list is stored as a setup in a table and applied in the OnLookup trigger. Of course, setting a table relation is easier that handling it in code, but its simplicity should not lure developers into bad coding practices.
Thanks again Alexander,
I swear I tried that originally. Do you know of any Business Central tables that are used for the purposes of storing filter data like that? Or should I just create my own.
Business Central’s “pay per table model” sure forces me to think different when it comes to data storage.
Yann
There is no specific table to store filters, this is rather something specific for the functionality you are developing.If it’s a filter on item categories, probably you could extend the Inventory Setup table. I would maybe choose a different approach - add a Boolean field to the Item Category table and show only those categories where this field is True.
