Table Box with assistedit button problem
Hi all, I have a tablebox in which I’ve dropped a textbox. In this textbox I would like the assistedit button to always appear on every line of the textbox. The permanentassist property is ignored when the textbox is put into a column in a table box. (That’s what it says in the help files). At the moment the user has to click twice in the textbox, once to get on the line and then twice to click on the assistedit button. Is there a workaround that anyone knows? Thanks in advance. Regards Shaz
Hi Shaz make the Assist Edit property of the text box to yes on the form. Kumar
Hi Kumar, The assist Edit Property for the text box is set to Yes. The textbox does show the assistedit button but only when you click on the line but I want the assistedit button to appear on every line of the textbox on entry of the form for example. Regards,
