I have created one table in nvision financials using programming lizences and given access rights to a ordinary user for that table. When the user trying to access that table through a report System given message like access denied . Why ? Any solution ? Thanks
Is the table included in the users license ?
quote:
Originally posted by rmotzer: Is the table included in the users license ?
No . How we can include that table in user licience
Joseph You purchase additional tables in blocks of 10 from Navision Software. Options are table designer and 10 tables or just 10 tables. same as additional Reports, Forms & Codeunits Navision will then cut your customer a licence with the new tables on! David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk
Hi David I the user license file its already written as 7,130 table designer 1 7,730 application module Table 1 8,200 application module Table (10) 1 What this means ?. Thanks.
Remember you have to allocate the specific object numbers you need. You could make a form/report based on the virtual table “Permission Range” to check your license-permissions to specific objects. Or have you NSC og NTR send you the print of the license details from the C/CAPS configurator. /Soren
Joseph I the user license file its already written as >> 7,130 table designer 1 If you have brought table designer then it comes with 10 tables 50000-50009 7,730 application module Table 1 Not sure about this one 8,200 application module Table (10) 1 This is one additional set of tables, when the order was placed the Number range would have been given by the purchaser Contact Navision for the numbers to use, remember to add then to user permissions. David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk
This may be a simple permission problem. If you can access the table using the client’s license and a user belonging to the SUPER group (unrestricted access), then it is just permissions. You will have to modify or create a group with access to your new table, and add that group to the appropriate users. Good luck! Regards, Mark Dielmann
