SysQueryForm add field in lookup
I would like to add the field_id in the range lookup to see the true database fieldName but I`m not able to display any row in lookup.
Is it possible to modify sysqueryform lookup?
public void lookup() // this is what i have tried
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tablenum(TmpSysQuery),this);
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
queryBuildDataSource = query.addDataSource(tablenum(TmpSysQuery));
sysTableLookup.parmQuery(query);
sysTableLookup.addLookupfield(fieldnum(TmpSysQuery,FieldLabel));
sysTableLookup.addLookupfield(fieldnum(TmpSysQuery,field_id));
sysTableLookup.performFormLookup();
Field_Id has the Visible property set to No. Isn’t that the problem?
Actualy I want fieldName and not field_id sorry.
In the form sysQueryForm, the datasource → Range → fields ->FieldLabel have the method lookup.
I think this is where I should add my field FIELDNAME
I saw something
http://kiwiaxguy.blogspot.ca/ → Filtered lookups on SysQueryForm
using the public void lookup(FormControl _formControl, str _filterStr) method for customisation
But in my case i just want to add field name beside field label in the lookup feilds… should`nt be hard… but hard for me :stuck_out_tongue:
I maid a temporary solution that display the fieldName in a textbox by modifing the method Range.FieldLabel: modified
public void modified()
super();
range.LookupButton = sysLookup::lookupValidate(range.RangeStatus, range.Table_Id, range.Field_Id);
range_ds.setLookupButton();
fieldNameResult.text( dbutil::FieldName( tableId2Name(Range.Table_Id), Range.Field_Id));
This is what Im trying to get on the query form.
A new column fieldName
I think you already reply to a similar request back in 2011
http://dynamicsuser.net/forums/p/47447/240899.aspx
Use SysTableFieldLookup class. Pass the form query to the constructor, save TableId to TmpSysTableField table (DictTableId field) and pass it to performLookupField().
I`m trying to follow you instruction here but my level of expertise is not enough to follow your instructions…
Could you elablorate a bit more or in the best world … a small .xpo that represent these changes.
Thanks Martin
simple code
at classDeclaration
SysTableFieldLookup tableFieldLookup; // function for lookup field
TmpSysTableField tmpSysTableField; // to catch selected lookup value
at lookup method:
query.addDataSource(tableNum(SalesLine));
tableFieldLookup = new SysTableFieldLookup(query);
tmpSysTableField.DictTableId = tableNum(SalesLine);
tableFieldLookup.performLookupField(this, tmpSysTableField); // lookup display label description
at modified method after super
FieldId fieldIdNum;
fieldIdNum = tableFieldLookup.parmSelectedRecord().FieldId; // get the field id
Hi Dominic,
What you should do is create a display method on TmpSysQuery like so
display FieldName FieldName()
return fieldId2name(this.Table_Id,this.Field_Id);
then add the display method to the grid on the form SysQueryFieldLookup. make sure the datasource “Allfields” is set as the datasource of the display method control which you added.
I think that is about it. The lookup should now have the field label as well as the fieldname. You should be able to take it from here.
-Albert.
