I am using a temporary table to populate SysLookupMultiSelectCtrl control.
Filling the temp table at runtime .
However there is no record at UI Level.
Records are inserting into table as when I make the table as regular same code is filling records in it and i can see those after execution too.
However on changing the table type to tmp or inmemory then no records are showing at UI.
Thanks in advance
Neetu
