can somebody help me… here is the scenario…column1 and column2…column1 is a boolean values yes /no…if column1 value is NO then column2 is disable/editable else column2 enable/editable…can someone help me with the code and where to put it…or if there is a way to set it up… in nav5
Place the below code at column1 - OnValidate() (Go to the design mode of your form click column1 control press F9 you can find Column1 - OnValidate() trigger).
is tthere a way to disable column1 row 1? in the requisition worksheet version NAV5
here is the situation… if column1 is yes then column2.disabled (true) else… but i would like to disable (column2 row1) only…so that in the next line column2 should be disabled(false) is this possible???
can you try this column1 is confirmed column and column2 is vendor no. column… …vendor no. can still be edited even if confirmed column has a value of no…
yes that’s possible (if I understood it right what your trying to do). Just place your code in the onaftergetrecord-trigger then it should work this way:
You tick col1 in row 1 → col2 isn’t editable anymore
You don’t tick col1 in row2 → col2 in row2 is editable.
