I have created a form that displays records from the Object table (filtered by Type=Table) in the header, and the Field table (filtered by the current Object.ID) in a subform.
The purpose of the form is to allow the user to mark any number of fields in the table (as excluded), and then generate a SQL script for that table to Sync the two tables in separate databases.
My issue is that I keep getting a “Field cannot be modified in this form.” error (referring to the Field subform). The thing is I never actually attempt to modify the records in that subform. Furthermore this error does not prevent the rest of my code from working properly. When I click OK on it, everything happens as I expected it.
If you need more informtion, let me know and I’ll be happy to supply it. Any thoughts would be great. Thanks in advance for your help.
In OnAfterGetRecord of the main form I have a function that looks up previously marked records, and then finds and toggles the mark on that record using the code
MARK(NOT MARK);
OnAfterGetCurrRecord is empty and I am not using CurrForm.UPDATE.
