hai there all…
i just started using Navision Sp 3
but i only use it in my local database
I want to tested it before i use it live for my company
i believe many of you have used it already
and I need advice from you…
have you give me a hint what are the benefits using Nav SP3 than the previous Nav?? (NAV SP2 and SP1)
is it far more extraordinary than the previous 2 navision service pack?
thanks for the info anyway
This document will answer to all your questions
http://dynamicsuser.net/files/folders/documentation/entry86020.aspx
okay then… thanx a lot nuno
is there any from another?
