This is my report I developed this through code but I’m not getting sub totals for each accountNum records.I want the output through code not by setting properties like SumAll = Yes
I wrote this fetch method,
public boolean fetch()
Query q;
QueryBuildDataSource qbd,qbd2;
QueryBuildRange qbr;
QueryRun qr;
q = new Query();
qbd = q.addDataSource(tablenum(CustTable));
qbd2 = qbd.addDataSource(tablenum(CustTrans));
qbr = qbd.addRange(fieldnum(CustTable,AccountNum));
qr = new QueryRun(q);
while(qr.next())
if(custTable.AccountNum == custTrans.AccountNum)
custTable = qr.get(tablenum(CustTable));
accountNum = custTable.AccountNum;
element.execute(1);
custTrans = qr.get(tablenum(CustTrans));
amountMST = CustTrans.AmountMST;
element.execute(2);
subtotal = custTrans.AmountMST;
subTotal1 = subTotal1 + subTotal;
element.execute(3);
subTotal1 =0;
return true;
I’m not getting exact output what I want .please help me to solve this ASAP.
In programble section 3 add display method and return the value subtotal1
Hi Saju,
I tried the same what you said but I didn’t get the exact output.
You need to replace that " subTotal1 = 0; " after the loop ends!
kranthi
December 19, 2012, 7:04am
5
Below is an example job, hope this helps you
static void printTotalSubTotals(Args _args)
Query q;
QueryRun qr;
CustTable custTable;
CustTrans custTrans;
real subtotal, total;
CustAccount custTableAccount;
boolean printTotal = false;
q = new Query();
qbd2.relations(true);
qbd2.joinMode(JoinMode::InnerJoin);
while(qr.next())
if (custTable.AccountNum != custTableAccount)
custTableAccount = custTable.AccountNum;
if (subTotal || printTotal)
info(strfmt(‘SubTotal - %1’, subTotal));
subTotal = 0;
printTotal = true;
info(strfmt(‘Header - %1’, custTable.AccountNum));
info(strfmt(‘Transactions - %1’,custTrans.AmountMST));
subtotal += custTrans.AmountMST;
if (subTotal)
info(strfmt(‘SubTotal - %1’,subTotal));
if (total)
info(strfmt(‘Total - %1’,total));
Hi Kranthi,
Thanks for your quick reply.
Problem Solved.
