Subject: CrossCompanyAutoQuery on the form and SaveDataPerCompany on the table
I have a form similar to the salesTable.
The main-Datasource and the joined datasource are set to
"CrossCompanyAutoQuery = true" because otherwise my filter-fields are not
work.
The main-table have the setting "SaveDataPerCompany = No" and the joined
table "SaveDataPerCompany = Yes".
Now I have the problem, that I can`t create new records with the
standard-functionality. Not in the main-datasource and not in the joined
datasource.
If I set the "CrossCompanyAutoQuery = No", then I can create new records,
but my filter-fields are not work.
Any ideas why I can`t create records, when the datasource is set to
"SaveDataPerCompany = Yes"?
