Hi guys I have one question in dynamic nav 2009 i want to make analysis by dimension this analysis by stuff account to every employee the problem when i make stuff to every employee total amount not shown. why
the picture as below
Can any one told me how i join between total amount and Employee for stuff account
please any one help me
thanks
Have you created the Analysis View to display the relevant data. ???
How i make Mr Amol please help me
What i make until now i go to setup-Dimensions-Analysis View-Analysis View Card then i add analysis view but I Cannot join this with total amount how i can join
Analysis View entries are created by the program when you update an analysis view. An analysis view entry is based on one or more G/L entries that fulfill a number of criteria concerning posting date, account number and dimension information that you have specified for an analysis view.
When you define an analysis view, you can define what information should be shown in that view. For example, you can specify which dimensions and dimension values G/L entries must have in order to be included in a view. You can also specify whether only G/L entries posted to certain accounts should be included in an analysis view using the G/L Account Filter function. When you update an analysis view, the program compresses G/L entries that fit the criteria that you set for the analysis view and creates analysis view entries. Each analysis view entry represents a unique combination of posting date, G/L account number, and dimension values.
An analysis view entry can therefore be made up of many G/L entries, depending on what date compression you have set for the analysis view. If you have chosen not to date compress analysis view entries, each analysis view entry will be equal to one G/L entry. However, if you have chosen to date compress analysis view entries, all G/L entries within a period with the same combination of posting date, G/L account number, and dimension values will be regarded as a single analysis view entry.
By clicking the AssistButton in the Entry No. field, you can view which G/L entries comprise the analysis view entry
Now mr amol i thank you very much about you tell me what i made until now is
go to analysis card and
create new analysis view code as code name : Emply
then select g/l account filter is 1120201(account number stuff account)
date compression is select : day
starting date 01/01/12
update on posting check mark selected
then in dimension tab select dimension 1 code Employee
then select update button
after this this code as below
Code Name Include Budgets Last Date Updated Dimension 1 Code Dimension 2 Code Dimension 3 Code Dimension 4 Code
EMPLY Emply No 28-11-12 EMPLOYEE
and i see analysis view entries table already updated in table as
EMPLY 1120201 1023 31-10-12 0 -1,000.00 0.00 1,000.00 0.00 0.00 0.00
more records this is sample
now when i make analysis by dimension and i select analysis view code :emply
and show as lines employee display all employee but no total amount for stuff account
although entry already exist and what is the problem now
thanks
Look at the Date filter field whether it is properly set as normally when we run the analysis by dimension system shows irrelevant date filter ,so change the date filter and check.
