Strange import error
I have to upgrade some customized objects to nav 2013.I have followed the necessary steps and have converted the oldcustom object file through TextFormatUpgrade2013 tool.Now when I am trying to import the file to Nav 2013 I am getting a strange error which is as follows-
’There is a syntax error in the import on Line 1,in position 0:Table 50007 PO Details Master 1 08/28/10 2:44:47PM A new object should start here’.
Please help.
Can you paste few lines from Line 1 in your text file…
Ma’am I did not understand what you meant by pasting few lines from line 1.Please explain.
Besides when I tried to import only that particular table (50007)no error occurred.
Besides when I tried to import only that particular table(i.e 50007) no error occurred.
Is your problem solved or nnot?
no,not yet because many of the tables are showing errors when I am trying to import individual table.
Are you trying to import txt file?
if yes, can you paste first 10 lines from your txt file here…
Yes Ma’am,I am importing a text file.I have pasted the first few lines here.
Table 50007 PO Details Master1 08/28/10 2:44:47 PM
1480 Webel Commercial
Table 50008 Purchase Special Term1 08/23/10 2:25:59 PM
896 Webel Commercial
Table 50009 Indent Special Term1 08/27/10 11:28:08 AM
1020 Webel Commercial
Table 50010 Recommended Vendor List1 08/27/10 11:55:11 AM
932 Webel Commercial
Table 50011 Item Details1 08/25/10 12:14:46 AM
4216 Webel Commercial
Table 50012 Item Long Description1 08/25/10 12:50:33 AM
1080 Webel Commercial
Table 50013 Item PO Details Master1 08/23/10 4:50:02 PM
1152 Webel Commercial
Table 50014 Rate Contract Details Master1 08/25/10 2:09:21 AM
1872 Webel Commercial
Table 50015 Item Vendor Details1 08/23/10 5:11:11 PM
this is followed by some code which are not readable and it is like this-
LookUpCity ValidatePostCode LookUpPostCode < f Ûÿÿÿ f øûÿÿ f ëÿÿÿ … , … - f öÿÿÿ ‰ ( ‰
RESET FINDFIRST SETRANGE
Filed Revised MODIFYALL Deductor Post Code # Responsible Person Post Code < f Ûÿÿÿ f øûÿÿ f ëÿÿÿ … + … , f öÿÿÿ ‰ ( ‰
Filed Revised MODIFYALL Collector Post Code # Responsible Person Post Code ì
a ÿÿÿÿü ü ” a a Ø e Ee D ee ee 2e e $ ee e e e … ee e e /e e e Ø ee e e ÿÿÿÿe e ee e e ÿÿÿÿe e e … ee e e e ee e e a ÿÿÿÿee e ee e e ÿÿÿÿee e e {e < , ( ( T , pe de re ƒe e re 2e re ee We ee re he re ]e e qe ee We e Ze e qe de re /e re ee We e re he e qe De Ze e qe ee We e Te ƒe e Ve e Ue Ze e qe ee We e Te ƒe e Ve e Ue Ze e qe de re ee We e re he re ]e e qe XeH IF CONFIRM(Text16501,FALSE,FIELDCAPTION("Post Code")) THEN BEGIN e qe ee We e Te ƒe a e a Ve ƒe e Ue Ze e qe ee We e Te ƒe e Ve ƒe e Ue Ze e qe be Ze e be Ze e Ee D ee ee 2e e $ ee e e e … ee e e /e e e Ø ee e e ÿÿÿÿe e ee e e ÿÿÿÿe e e … ee e e e ee e e a ÿÿÿÿee e ee e e ÿÿÿÿee e e {e < , ( ( T , pe a de re ƒe e re 2e re ee We ee re he re ]e e qe ee We e Ze e qe de re /e re ee We e re he e qe De Ze e qe ee We e Te ƒe e Ve e Ue Ze e qe ee We e Te ƒe e Ve e Ue Ze e qe de re ee We e re he re ]e e qe XeH IF CONFIRM(Text16501,FALSE,FIELDCAPTION(“Post Code”)) THEN BEGIN e qe ee We e Te ƒe a e a Ve ƒe e Ue Ze e qe ee We e Te ƒe e Ve ƒe e Ue Ze e qe be Ze e be Ze e Ee 4 ee e ee ee e e {e oe OnValidate ee We e Te ƒe e Ve ƒe e Ue Ze e Ee 8 ee e ee ee e e e {e oe OnLookup e ee We e Te ƒe e Ve ƒe e Ve e Ue Ze e Ee T ee e ee ee e ee a e ee e e {e 0 oe OnValidate ee We e Te ƒe e Ve ƒe e Ue Ze e ee a Ze e ee Ze e Ee 8 ee e ee ee e e e {e oe OnLookup e ee We e Te ƒe e Ve ƒe e Ve e Ue Ze e a
# ( - Code Description Name Name 2 Address Address 2 City Phone No. Phone No. 2 Telex No. Fax No. Post Code Home Page
L.S.T. No. C.S.T No. dl ´Ã Commercial Job
ei „¿1 Webel Commercial Ø8 ò‡Ø8 ´8 d | L d d d _ ¨ 𒇩$ d GR µÃ HR µÃ , 0 @ ð ‰ $ 0 . | ð ‰ $ 0 ‰4 È 4 ‹L h 4 ‹P a 4 ‹T @ ð ‰X 0 -p $
0 2l€ 4 ‹x 0 -|8
ð ‰ä< ð ‰ü< ð ‰P ð ‰,, 0 -D4 ð ‰x¨ 4 ‹ 0 .” 0 .˜ 0 .œ 0 . t 2 𠉤$ 3 0 ‰¼( 4 0 -Ôp 5 ð ‰< 6 ð ‰ 7 0 -8h 8 ð ‰XT 9 0 -pX : 0 -¤L ; 0 -ØH < 0 ‰ø( = 0 - > 0 .PL ? 0 -T@ @ 0 .t( A 0 .x B 0 .| C 0 2€ D 0 2Œ E 0 2˜ F 0 .¤ G 0 .¨l H 𠉬 M 0 -¸ Ø Project Code ; = § @ b Project Job Date b Project Executing Dept. ; = ‚à @ <9 //Automatically Validated By System from Login Details Old Project Number @ Type of Project ¸!X P Large Capital Petty Capital Maintenance Others d(P Large Capital Petty Capital Maintenance Others Source of Fund ¸!( Own Govt d( Own Govt Project Job Against ¸!| t Customer Enquiry Tender Market Intelligence e Internal Requirement
Sale Order d(t Customer Enquiry Tender Market Intelligence e Internal Requirement
Sale Order e Requirement Category ; = µÃ @ Scope of Work @ ú Estimated Cost(Incl.Tax) Budget Status ¸!4 , Budgeted
Unbudgeted d(, Budgeted
Is it txt file or FOB?
Did you open FOB in txt file?
While you ran TextFormatUpgrade2013 tool, it has massed up some curly bracket. Open the formated object file, this should be .txt as you had worked with textformatupgrade tool.
look at the first line, export existing object to txt file and compare, how the first line should be.
