I am getting the strack trace error while opening the forms and postings and also reports,
Stack trace: Field ‘FromPostalAddress’ in table ‘InventTransferJour’ has not been explicitly selected.
Stack trace: Field ‘Correct’ in table ‘VendTrans’ has not been explicitly selected.
Please suggest me solution as soon as possible.
Phani.
This has been discussed here, http://dynamicsuser.net/forums/p/59801/413045.aspx#413045
many issues related to this were been fixed, which version you are using.
Hi Kranthi,
I am using AX 2012 R2 + CU 6.
Kernil version : 6.2.1000.1437
Application version : 6.2.1000.1437
Please suggest me solution, In Test Server every thing is fine but Production server we are facing the strack trace error in almost all the process.
Phani.
If test and production has same application and kernel versions, then the below setup might not have been done in test.
error on invalid field access in System administration → setup → server → server configuration
