Stopping a batch process immediately
I’ve a batch job that loops through a bunch of records and processes them. During the processing multiple levels of classes are invoked before invoking an external service. This service is sometimes down for extended periods of time. I can code for a timeout situation, trap the exception using a try/catch block, and act upon it.
I want to stop the processing immediately when the first timeout occurs. The only way I can think of doing it is bubbling up the error all the way to the loop logic in the top class and issuing a break statement so no further records are processed.
Is there a better way to stop the processing immediately at the lowest level without bubbling up?
Thanks.
Why do you catch the exception if your goal is to stop processing immediately?
Martin,
Thanks for the response. You are correct. I just didn’t think it through before posting the question.
Raman
